compressed air
we do regularly at work, its a pretty quick way of doing it, you still will want to use a paintbrush as it doesnt get off all the dust it certainly wont damage it if thats what your concerned about. we use a compressor which runs around 100psi
spray it everywhere, its particularly useful for getting dust from around the cpu heatsink, compressed air in can will have liquid the lower the can gets so you have to be a bit careful as said above but even if you do get a little on there its unlikely to do any damage
oh right will give it a go
got lots of dust in the case and I want to get rid of it
damn those cans are expensive
to be honest, I would use a paint brush and a vacuum cleaner, its pretty safe to just use a brush to get rid of the dust and the vacuum obviously to suck it in, cheaper than compressed air anyway!
I did use it, but every time you tilt the can it sprays out a load of liquid nitrogen and i always thought it could damage my hardware so now i very gently use a hoover!
Try using one of those dusters that pick up dust using static. They'd work a treat.
DON'T DO THAT!
thats a stupid STUPID idea.
And air duster work a treat, but have a hoover running beside you (but not next inside the pc) because the duster just blows dust EVERYWHERE ELSE.
