A can of compressed air is a can of compressed airGo for the cheapest available I say
I disagree, the Falcon products areexcellent, the cheap supermarket ones are terrible!
Works a treat, and a lot easier than dragging hardware down to the garage, waiting for the compressor to fill up just for a few second blasts of air!Would a blast with a car tyre pump work or would there be static issues?
remember before you use it to spray it AWAY from the computer, in case you get a build up of water droplets in the can.
Terrible how?
Air pressure, nozzle design, etc etc![]()
. Nice 120PSI far better than the cans, its a shame you cannot get refillable cans of air.As cookeh really! The Supermarket ones are poor.
Even so, I use cans of Falcon Dust-off, I also have a compressor in my unit now. Nice 120PSI far better than the cans, its a shame you cannot get refillable cans of air.
