Worst case scenario you can't get the pads in how undrivable would the car be without a brake on a rear wheel?
Not sure if joking...Worst case scenario you can't get the pads in how undrivable would the car be without a brake on a rear wheel?
Dont forget to clamp the flexible brake pipe and open the bleed nipple to make it easier to push the piston back and stop any damage to the brake master cylinder.
So I'll have the bleed the brakes at the end also?
I'm sure this might be the absolutely belt and braces way of doing it, but I have never ever done this, nor have I seen any garages do this and IMO, it's completely unnecessary
Are you only replacing one side??So final question, to torque or not to torque. So do you torque anything like calipers, caliper carrier, location bolt. I should say I will be replacing the disc also(rear).
Most things I read are not to bother with torquing, it would mean buying a torque wrench.
