Compressing brake piston
Caliper winding tool for the rears, G clamp for the fronts and if auto handbrake, disable that first through OBD port (< yes, that's a thing)
I usually just use my fingers, or if that doesnt work, block of wood and a g clamp.
Take the cap off the fluid reservoir first.
Same. For most Toyota calipers at least if you cannot push them back by hand then you either skipped finger day at the gym, or your calipers are going to need a refurb soon.
Nutin but a G clamp on the fronts and rears if they have separate drum handbrake.
I use a rewind tool on a windy gun for the rear if it has them. Two of my cars have separate drum hand brakes which I think are far better.
So final question, to torque or not to torque. So do you torque anything like calipers, caliper carrier, location bolt. I should say I will be replacing the disc also(rear).
Most things I read are not to bother with torquing, it would mean buying a torque wrench.
Can you imagine the newspaper story if this guy ends up having an accident.
