- 13 Mar 2006
I'm going to give compression fittings a go for the loop I'm making atm, but I'm getting a bit confused...
I want to use 1/2" tubing, and I'm limited to using compression fittings with a maximum outer diameter of 25mm. The bitspower ones seem to be too big at around 26-27mm diameter for the compression fittings outer casing.
My googling skills are weak today - anyone know which of the 1/2"ID compression fittings are 25mm wide or less?
was in one of the many typhoon3 threads
