- 12 May 2010
- West Bromwich
I'm giving my loop the overhaul during the Easter holiday and need to buy some extra barbs. I'm going from a HAF-X with a gpu only loop and H100 to a white Enthoo Primo with a RX360 in the top and EX240 in the bottom + raystorm block.
When I originally bought the OcUK 360 kit, it came with six half inch barbs and 7/16 hose. Because it was might first loop, and I wanted peace of mind, I used some Koolance clamps too.
I've noticed the kits now come with compression fittings as standard. Are these easy to tighten up by hand? Are they better? Do you need to get a spanner on them to tighten them up properly.
Cheers.
Cheers.
