Computer fails dmi data pool check
10 Feb 2010
Oxfordshire
Hi all, i didnt know if this was a hardware or software issue so i have put it here for now until someone can enlighten me and move it if needed.
Saturday i went to switch the computer on for the first time in a little while (maybe a week) and it kept freezing at the above start up procedure. I had just put in a friends graphics card a week or so before this and the computer worked fine. I tried switching my graphics card back and would still fail at this point.
I got the thing started by pressing F11 and chosing to boot from Hard disk. Once started i did a hard drive check using Tune Up Utilities 2011 and that came back with no errors, so i restarted to PC with my old graphics card in and it still failed at this point again.
To get it to boot up normally without pressing F11 i had to go into the BIOS (its a locked BIOS) change to the boot priority to 1 - hard drive 2 - hard drive 3 - (cant rememeber) and change to hard drive priority to my other hard drive.
(np: i have two hard drive both 250gb one with Vista on as my usual hard drive and the other has my boot files on)
Why is this happening? Should i have to change my BIOS settings to get the PC to start?
If you need any more information than the above please let me know.
Many thanks, Chris
that i'm afraid i cannot answer, sorry. just remember reading it somewhere. how old is your pc and what are the specs. i guess the OS could be playing up too, tho i'd wait on more advice before doing a fresh install.
clear your cmos first and see how you go from there.
