When using my computer, or even when it's just idling, it'll freeze, the start bar will disappear and ctrl, alt, delete doesn't do anything. However, I can still press the num/caps/scroll lock on the keyboard and get the lights on and off. In order to progress, I need to turn the computer off with the button. When I turn it back on, it says that it is unable to load btmgr and I have to turn off and then on again and Windows 7 loads fine.
What do people think the most likely problem is? I don't have a Windows 7 boot disc, so I can't do a clean install of windows (though happy to cover postage and a pint if someone could post me one!).
I plan to do a memory test as well at some point, I have ordered a USB stick today so hopefully be able to do that tomorrow.
I'm thinking it could be a bad sector on my HDD? I have pretty old HDDs so maybe they are on their way out. However, I don't really want to spend the money replacing them if it's going to leave the issue.
Any other ideas?
Temperatures are fine across all components.
Any other ideas?
