Permabanned
- 14 Jul 2011
- Starship Enterprise
My computer is running a little hot at the moment when I'm on STO set at maximum settings with full antialiasing. and even when I put them slightly lower the temperatures are still high.
Graphics card (msi 460) hits 65-70 Degrees and hard drive hits 55 and the processor hits 60. If I leave the side panel closed it gets a lot hotter.
Its a small acer matx case, with space for only a back case fan slot, is it necessary to buy a new case? if I did fit a back fan would it make too much of a difference?
Spec: Athlon II x2 3.5Ghz, 460Gtx 1GB, Lepa 500w.
Everything idles @ 40-45
Will those temperatures be ok for a few weeks until I can afford a new case or shall I stick a back fan in?
Thanks.
image uploading
wordpress image hosting
image uploading
Thanks.
image uploading
image uploading
