Computer just caught fire!
21 Oct 2010
Or at least I think it did. Started smoking so I immediately pulled the power. No obvious signs of damage, never had liquid anywhere near it, any ideas what might have happened? Did find a cobweb inside, and some damp on the outside of the side panel, but the inside is bone dry :confused:.
TIA,
ng93
Sounds pretty alarming!
Generally speaking there isn't much in a PC that should be at risk of catching fire. You don't have labels attached to any cables (or anything like that) which could have strayed onto a heatsink do you? Failing that it might be something PSU related I suppose although I can't say I've every heard of one catch fire.
PSU gone pop I'd imagine, I'd suggest doing a sniff test on the inside of the case, the smell is normally very obvious. If it's the PSU smelling, order yourself up a replacement :)
Power Supplies are known to smoke/ puff when they go.
Unplug the PC and open the case up to see if you can see any visible signs of hardware degradation.
Post your full system specs.
Full specs:
2500K (at stock) with corsair a70
6950 toxic (unlocked shaders and factory overclocked)
msi p67-gd53
antec true power 650 (though these were supposed to be good!?)
a few hard drives
corsair force 3 ssd
8gb corsair vengeance lp (2x4)
By the time I got the side panel off the smoke had gone, i think there was a tiny bit left above the hard drives but no idea if it was coming from them. Had the computer for nearly a year no problems (well quite a few F4 BSODs but a reinstall made them much less frequent). Smoke came out the top so don't think it would be the psu which vents out the back? Had a look around but can't see anything wrong, no burn's or anything.
Is it safe to try turning it back on to see what the problem is?
Looking at it now there's nothing blown on the motherboard, no loose wires (some loose sata power cables round the back but they shouldn't short?), all the cables are properly plugged in, nothing loose, shouldn't have overheated as wan't doing anything intensive and I could hear the fans working. No burn marks anywhere.
Can't see much because of the shroud, but what I can see on it looks fine (same with the psu). Not sure what else I can check? Hard drives and dvd drives all seem fine. So does the ssd. Everything looks good :confused:.
Just had another look at the hard drives:
Take it that's the culprit? Or could this be a PSU issue?
No wires or anything near it, the drive that was above it has a slightly burnt power connector, but doesn't look to be broken. The drive below has no marks what so ever. Just worried that it was caused by a faulty PSU, anyway to check?
