I've just built a new rig for a friend, everything has installed fine, windows runs fine but I just keep getting random freezes every now and then, I'm clueless to what is causing it?
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel (OCZ3G1333LV4GK)
Logitech Illuminated Keyboard (920-001165)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS)
Pioneer DVR-S18L 22x DVD±RW SATA Labelflash ReWriter - Black (Retail)
TP-Link 300Mbps Wireless N PCI Adapter (TL-WN851N)
Akasa Internal Media Card Reader (AK-ICR-07)
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard
Intel Core i3 530 2.93GHz (Clarkdale) (Socket LGA1156) - Retail
23 Dell P2311H LED
SStone 450W Strider ST45SF
1 SST SUGO SG02B-F SFF BLK GLOSS
The only thing I can think of is the memory? I will run memtest soon to check that.
Also everything is at stock/auto in the bios apart from the memory voltage which is set to 1.64v.
23 Dell P2311H LED
