- 24 Apr 2011
Hi guys,
Ive created a number of threads on overclocking here as Im totally new to it and you lot have been helpful so far so thanks for that
Latest issue Im having is occasional failure to start up. The setup is an ASUS p8 P67 and an i5 2500K, and the overclock is 4.5 Ghz and a 1.35V Vcore. I have overclocked the Turbo as opposed to changing the voltage directly, and I have the LLC set to high as well. The problem is that occasionally when I switch on it will run the fans for a few seconds, then go back off, then start up again normally? I wasnt too concerned, but just now windows didnt start at all and it came up with a repair screen and suggested a system restore. I declined and restarted and its started up again fine, though Im a little more concerned now its come up with this error.
Do you guys have any idea if a setting could be causing this in the bios or something? Like I said, I havent fiddled with any of the other settings yet.
.Latest issue Im having is occasional failure to start up. The setup is an ASUS p8 P67 and an i5 2500K, and the overclock is 4.5 Ghz and a 1.35V Vcore. I have overclocked the Turbo as opposed to changing the voltage directly, and I have the LLC set to high as well. The problem is that occasionally when I switch on it will run the fans for a few seconds, then go back off, then start up again normally? I wasnt too concerned, but just now windows didnt start at all and it came up with a repair screen and suggested a system restore. I declined and restarted and its started up again fine, though Im a little more concerned now its come up with this error.
