16 Dec 2012 at 14:59 #34 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Yeh its not booting none of peripheraks are working trying the cmos again
16 Dec 2012 at 15:00 #35 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Im preetty aure its not psu how would that affect the boot up
16 Dec 2012 at 15:00 #36 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Really need to fix this
16 Dec 2012 at 15:02 #38 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Is there anyway to check out the cpu?
16 Dec 2012 at 15:03 #39 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Tbf I didnt shut the computer down properly last night I just held power button could this cause the problem
16 Dec 2012 at 15:04 #40 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 I need this comp for work .:/
16 Dec 2012 at 15:08 #41 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 I was reading about a cmos jumper pin must I remove this too...
16 Dec 2012 at 15:15 #42 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 I should also let you guys know that my cmos battery was directly below my gpu
16 Dec 2012 at 15:25 #44 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Hmmmmm is there anyway to check ny cpu jusy incasey best bet is the mobo
16 Dec 2012 at 15:26 #45 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Hmmmmm is there anyway to check ny cpu jusy incasey best bet is the mobo
16 Dec 2012 at 15:41 #48 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Is there anyway to test psu also the cmos batteey thing didnt work
16 Dec 2012 at 15:44 #49 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 I got spare 1155 mobo bit not cpu ; (
16 Dec 2012 at 15:46 #51 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 IF you were betting Man. What you think it is?
16 Dec 2012 at 15:48 #52 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 None OF peripherals are working
16 Dec 2012 at 16:13 #56 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Fans lights hard drive even the psu led is on but no boot up or peripherals
16 Dec 2012 at 16:16 #58 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 Il try overnight if thay dont work im on to buyin a cpu for my spare mobo 1155
16 Dec 2012 at 16:16 #59 vaulsey vaulsey Associate OP Joined 25 Jul 2011 Posts 277 I3 or something cheap
