So I've got the same problem I had a little while back of my PC consistenantly restarting itself for no apparent reason :/ I'm not sure what it could be at all in all honesty it was fine until a couple of days ago. I have my DRAM at 1.65V (because for some reason my mobo won't let me set 1.55V like I had previously? o.O) VTT at 1.104V (these both fixed the problem I had last time) CPU @ 4.5Ghz on 1.25V with LLC at level 1. It only really started happening after I reseated my cooler... (after I had it tightened on too much) theres no bent pins in the socket and the motherboard isn't being warped as far as I can tell.
No-one I know uses a desktop... all laptops and ipads etc. Useless to me! (I think I have a faulty rail considering RMA'ing it but I would like to test it first obviously! I don't suppose you would be so kind Pgi? xD You're somewhat close to my area
