Hello all, have to write my problem specification for my final year project and well im a little confused as to how I should structure this. The information I have been given is:
So has anyone else completed one of these and if so could I see it? No need for your whole writeup, this is just the initial problem description and like i say could do with being pointed in the right in terms of structure
Thanks
Once you have been allocated a project, you should spend approximately three weeks developing the problem specification, which should give a good overview of the problem to be solved, from the user’s perspective. It should provide a general description of the problem including, as appropriate, the way the problem is solved at present and the advantages and disadvantages of the present method. The goals and requirements should also be stated clearly. The constraints of the proposed solution should be specified, including a description of the environment in which the software is to be developed, i.e. the hardware/software platform on which it will run, performance constraints, other programs to be adapted or interfaced to. Verifiable criteria against which the success of the project is to be judged should be identified. Lastly, this should include a Gantt chart outlining the project plan with major milestones and deliverables highlighted.
Thanks
Then just revise little bits and pieces as required.
), but a friend who is doing a PhD swears by it.
