The thread has changed into a more, budget build rather than repairing my old system. (If a mod could potentially change the title to - "£650 Gaming Budget Build", would be appreciated rather than creating a new thread.)
I have a budget of £650~ with a HDD/RAM and CPU Cooler available to use for a new system build. I have been looking at the following mainly, if anyone has any suggestions/advice to which I should purchase and why please post.
Intel Build:
YOUR BASKET
1 x Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £221.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Gigabyte G1.Sniper M5 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £119.99
1 x BitFenix Prodigy M MATX Cube Case - Arctic White £65.52
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £49.99
Total : £648.90 (includes shipping : £17.85).
AMD Build:
YOUR BASKET
1 x Kingston HyperX 3K SSD 240GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/240G) £113.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £110.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £74.99
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £61.99
1 x BitFenix Merc Beta Gaming Case - Black £29.99
Total : £628.03 (includes shipping : £11.75).
Mainly irrelevant information below due to a change of topic
Hey all, I seem to be having this issue with my PC at the moment which usually occurs while playing games, but can also happen when I'm not.. it's quite random. The PC will kind of just lose power for a split second and then restart, however it does not boot back into windows as my monitors just remain with a black screen. I then have to hard restart the PC, and it then boots as normal. When it does turn off and tries to boot, a red light on the mobo is on when it initially tries to reboot.
I originally thought that it might have been a temperature problem. So I downloaded both Core Temp & GPU-Z to find out my temps, not sure if they're too abnormal.
CPU Idle - 37c
CPU After 20 minutes of Prime95 - 58c (no crash)
GPU Idle - 55c
GPU After 15 minutes of Rust (min settings) - 69c (crashed)
Current Spec:
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3)
Kingston HyperX Blu 16GB
Asus M4A87TD Evo AMD 870
Zalman Z7 Plus Midi Tower Case - Black
WIN POWER ATX-750
Titan TTC-NK85TZ/V2 Fenrir CPU Cooler
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
Nvida GTS 250
I was also thinking of upgrading and replacing the faulty(?) parts, or just building a new system with the newer parts the RAM / HDD. I have a budget of roughly £600~
Thanks for the help, it's much appreciated.
Intel Build:
YOUR BASKET
AMD Build:
YOUR BASKET
CPU Idle - 37c
GPU Idle - 55c
Current Spec:
WIN POWER ATX-750
Nvida GTS 250
