Computer Upgrade to Ryzen 7
8 Nov 2017
Hi Everyone,
I am about to upgrade my current set up to Ryzen for video editing. I just wondered if anyone would check my part list out to see if I made any bad choices or maybe put parts together that don't work well. I was kind of confused as to what ram and mobo to get so I kind of just picked a random one that sounded good.
I already have a GTX 970 and a good power supply so they are not on the list.
CPU (Comes with a fan):
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-39x-am.html
Mobo:
https://www.overclockers.co.uk/asro...ocket-am4-ddr4-atx-motherboard-mb-153-ak.html
Ram:
https://www.overclockers.co.uk/kingston-fury-white-16gb-2x8gb-ddr4-pc4-19200c15-2400mhz-dual-channel-kit-hx424c15fw2k2-16-my-279-ks.html
Boot SSD:
https://www.overclockers.co.uk/sams...3.0-x-4-nvme-solid-state-drive-hd-228-sa.html
Optional m.2 SSD (Could use a normal SSD instead) to edit from:
https://www.overclockers.co.uk/cruc...lid-state-drive-ct525mx300ssd4-hd-067-cr.html
3tb hard drive for storage:
https://www.overclockers.co.uk/seag...64mb-cache-hdd-oem-st3000dm008-hd-36l-se.html
Cheap case as I don't mind what its in as long as it works:
https://www.amazon.co.uk/BitFenix-B...ts=p_n_feature_keywords_browse-bin:1031697031
941.44 Pounds in total (Maybe can save money on the mobo with a smaller one and a normal ssd)
I was also looking at this deal which comes pre over clocked as I am not confident doing that sort of thing but not sure really:
https://www.overclockers.co.uk/gren...overclocked-gaming-bundle-bu-08w-og.html#t=b1
Thanks for your time.
The Pro4 has a turbo M.2 slot and a slower M.2 slot. Stick the faster one in the turbo slot (if you happen to get 2 x M.2s by any chance).
But also, it's the faster drive that should be used as cache/scratch for your editing programs. The SM961 is a great choice for this. A regular SATA or SATA-speed M.2 like the Crucial MX300 would be fine for boot/programs drive. I'd go with 250GB boot and 250GB scratch disk.
