I've purchased an Xbox 360 from a very large AV forum (well not the forum itself but someone on it.. you get the idea)
Anyway it's a 360 Arcade and it's arrived this evening. I've got it hooked up via the HDMI cable and everything seems to be fine so far. I've tried a bit of Tiger Woods 07 and that plays fine.
My concern is it looks like the warranty sticker has been carefully removed and put back on. It was manufacturer last September so logic would suggest that anything failed it would have been covered and sent back to MS or the shop it came from which makes me suspicious as to why the sticker has been tampered with.
I've got it hooked up to my router and running the network tests it passes them all (DNS, NAT, ICMP etc) but when it gets to "Xbox Live" it detects an update. As I've got not hard drive for it yet I can't download/install the update and it flicks back to the previous screen and the word "Fail" appears after "Xbox Live".
Does it say fail simply because there's no storage device attached and therefore it cannot create/login to a profile in order to access Xbox Live, is it saying Fail because I can't download/install the update or finally is it because the previous owners been banned from Xbox Live?
