- 6 Oct 2012
- (do-or-die) Wye, Ashford, Kent, UK.
i currently have one hd with vista 32 installed.
i have just installed a 2nd hd which is waiting for me to install windows 7.
upon reading various forum posts, i have discovered there are 2 ways to do this.
1) unplug the current hd.
install windows 7 on the new hd.
reconnect the first hd.
reboot.
choose which drive to boot by going into the bios.
on one forum post, someone mentioned doing a 'proper' dual boot system (quoted below).
"What's wrong with a proper dual boot system? Install the older operating system first and then the newer operating system. You will then get a boot menu enabling you to choose which operating system you want to load."
this confused me somewhat, as i already have vista 32 installed on the 1st (older) drive.
does the poster mean to suggest not unplugging the 1st drive and carry on installing windows 7 onto the new hd?
i do like the idea of having a proper screen prompting me to choose which drive, instead of having to go into the bios every time i wish to choose between the two drives.
one other thing:
if i go ahead and begin installing windows 7, will there be a prompt asking me to designate what hd i would like to install it to, or do i have to go into the bios and select the new hd so it knows where to install it to?
(i had a horror moment whereby i thought if i went ahead with the installation it would install over the top of my current vista 32 os without warning!
i'm sure i would be warned beforehand by windows if such a situation arose, but still..).
better to be safe than sorry, so i thought i would consult earnestly with you guys/girls
reboot.
one other thing:
