Configuring Oblivion for best fun with mods
31 Dec 2005
Glasgow
Just got Oblivion. Just wondered if the fps im getting is about right for my system?
indoors (ie at the start sewers etc) i get between 40 - 60 fps at 1440 x900 widescreen HDR most settings on high except for shadows. Changed the grass texture thing from 80 to 160 in the .ini file as well.
Outside i get from about 20 - 60 fps depending on the clutter around me i think. But it looks ******* gorgeous!! How do i take screenshots?? ctrl and printscreen?? Looks better than the xbox360 version i used to have albeit i played that on a normal tv screen :)
So no real problems but the fps does seem weirdly unstable at times i.e. look at wall im getting 60 fps then i turn around and look somewhere else and it drops like 20 fps.
If i run it at higher native resolution with similar or slightly reduced settings i maybe lose about 5- 10 fps but its not totally unplayable either :)
Also planning on adding quite a few mods as im always keen on modding games.
The list of mods i have downloaded(but not installed yet) is as follows, possible conflicts you reckon?
No more annoying messages
Landscape LOD texture replacement
Landscape LOD normal map fix
No Psychic guards 1.2
Beautiful stars
Better grass texture without tiling
Skill perk description enhancements
Real Lava
Book Jackets High res
BTmod 2.20
Cyrodil transportation network
MD_natural faces v095
natural environments
attack and hide v20_bundle pack
quest award levelling
Stormier storms
thievery 1.0 and patch 1.2
Wizardry mod gamma
Unoffical oblivion patch v151
Also im not sure which of these two i will install either@
Obscuros Oblivion Overhaul 1.2
Francescos levelled creatures_items
One thing i hated about the 360 version is how everything levels up with you which is why i want to install either of these 2 mods.
Any other mods you can recommend?
cheers
I spent an age tweaking with mods and settings, so much so that i really forgot about playing the game. Most of the mods should be compatible, would def go with OO's mod though.
