- 9 Apr 2004
- Bornholm, Denmark.
OK, I'm going to sounds a bit nooby here probably, but want to check my thinking..
I currently run an Athlon 64 3700+ with some PC3200 RAM, as that is the highest stated RAM spec for my ASRock board. However I have a fairly tasty overclock on the FSB (For the stock cooler anyway), as you will see in the sig, which requires me to rein in the RAM else I can't boot (Run it set to 333 in BIOS as this results in near 400 in reality)
Am I right in thinking obtaining some higher rated sticks of RAM would allow me to unleash more of the FSB to the RAM, or are there other factors invilved that would prevent my from running higher rated RAM in my mobo?
Although, even without a clock I can't take 1T.. just fails to POST using Crucial Value Selects
