Hi all,
PC (in sig) has been running solid as a rock.
Was playing Total War last night and everything was fine. Powered the unit off as normal - went to bed. All standard so far.
This morning however the unit won't turn on. Lights on the motherboard are on but when pressing the power button the fans on the h100i spin about a centimetre and the unit doesn't boot.
I've tried a separate kettle lead and tried at a different plug socket to make sure fuses wasn't the issue however the same occurs.
It's a Superflower Leadex 1000w Platinum white power supply.
With that limited information would you be able to say it's the power supply itself?
Thanks for any help.
Sean
Sean
