- 18 May 2010
Hi,
I hope this doesn't turn out to be simple as I will feel a bit simple.
In my hall way I have two switches, one is separate and controls the landing light, obviously this light is also controlled by a switch on the landing.
Separately there is another switch right next to the one above, it controls the entrance hall light and the porch light with two separate buttons.
I would like to do one of two things -
1 - replace both switches for smart switches like for like so they are two separate smart switches one controlling the same lights that they do now
Or
2 - replace the two switches with one smart switch with 3 buttons that controls the lights in the same that they do now
I'm not sure 2 is possible I can't see anything that does it, I think I need a two way smart switch to replace the current two way switch and a separate double smart switch to control the porch and hall.
Do I have this right and any recommendations on what will help me achieve this please?
Also as well as using Alexa will I be able to use two Separate smart phones?
Thanks
Or
Thanks
