Confused about which shower pump
28 Jul 2003
South Wales
Im having some bathroom work done next week and one aspect is a shower pump.
Im looking at positive head pumps and will only run one shower currently. I can't decide between the salander ct75+ http://www.salamanderpumps.co.uk/positive-head-shower-pumps_twin-impeller-regenerative_ct75 or the Rsp50 http://www.salamanderpumps.co.uk/positive-head-shower-pumps_twin-impeller-centrifugal_rsp50
They both seem to cover what we need (run a shower) but the rsp50 although less powerful (i know that's not always needed) runs quieter.
Can anyone advise what I should go for?
Any reason you're comparing the 50 and the 75?
The other point that strikes me is that the 75+ only does 30 minutes continuous operation. If you have a family living with you, and you all shower one after the other in a morning, you might be pushing the design limits of the pump (not saying it'll be a problem, but it might shorten the lifespan of the pump).
I think because the ct55+ hasn't got much in the spec dept and the rsp50 is suitable for what I need.cost came into it too where they are both around. 170-180.
I think the rsp50 is continuous rated (although only 2 adults so won't go past 30mins constant) and its quiet rated
I'd personally take the extra 0.6 bar then and go for the CT75+. That's purely because if there were only two of us in the house then waking up the household with a loud shower pump is less of an issue, and the extra blast in the morning would be appreciated :).
