Confused between 2 Laptop choices
6 May 2021
Hi
I am confused and looking for suggestions for my new gaming laptop choices.
1st choice
Lenovo Legion 5 15 AMD Ryzen 7 6800H 16GB RAM 512GB SSD Nvidia RTX 3070 Ti 15.6" IPS QHD 165Hz Gaming Laptop - 2022
2nd Choice
ASUS ROG Zephryus G15 AMD Ryzen 9 6900HS 16GB RAM 1TB SSD Nvidia RTX 3070Ti 15.6" WQHD 240Hz Gaming Laptop - 2022
I returned the Razer Blade 15 Advanced RTX 3070 240Hz QHD, because it was literally a frying pan to type on, idle temps were 60-68. So please advice me which one should I go with and which will stay cooler during normal usage and coding.
The price difference between the two is £300
Regards
Hi
1st choice
2nd Choice
Regards
Why worry about high idle temps? Its just because the fans are dialled right down foe quietness. Or was it actually warm to the touch?
The specs speak for themselves. This is only something you can answer in all honesty.
I am tempted to get the Asus but lenvo Legion design I like it. Will I be losing too much performance if I go with the 6800h? One problem with the Asus is that the max memory support is 24GB. So in future if I want to upgrade the RAM will be stuck with 16GB single stick rather than 2x16GB
This dude does a lot of laptop test. From what I've seen, the Legion is the one to get, but Asus aren't far behind.
You can see on the thermal image tests that the Razer does indeed get hot on the palm rest area.
For the Razer blade, then I must have got a bad batch from Amazon. His temps on idle are normal 43. My blade was sitting on 60-69 and little browsing shoots it up to 75 C and the keyword was extremely hot and the palm rest as well. I returned it. I guess I will go with the Legion and save £300, 6900hs to 6800h won't make much difference I assume
Did you go for the Legion ?
I recently bought a Legion 7 (5800h/3070) and my kids have had Legion 5 Pros (5600h/3060) since Christmas.
I was put off the Zephyrus because the rear exhaust blows against the bottom of the screen. I wouldn’t place the rear of my laptop right against a surface, the recommendation is always to leave some space so this design seems surprising (but does look nice). I also wouldn’t want hot air constantly getting blown directly onto the screen.
How are the temps when on idle and normal workload? Does the keyboard area get too hot and uncomfortable?
Did you grab the £999 deal for the Legion? I've been debating it
On my Legion 7 the keyboard area barely feels warm when idle or under normal use. It does warm up when gaming, mainly around the centre, the left side (WASD) doesn’t get as warm. The keyboard doesn’t get uncomfortable. The track pad area in front of the keyboard remains cooler.
The only surface that does get towards being hot is the area above the keyboard.
At idle CPU temp is around 40C with GPU around 35C. With normal desktop usage CPU goes upto 45-50C.
I checked when playing Destiny 2 earlier (running at 2560*1600, FoV at 95, vsync on and set to 83 fps and its solid at 83fps). Under the balanced profile the CPU temp got upto around 76C and GPU around 70C.
I’ve asked my kids about the Legion 5 Pros and they say that keyboard temps are fine. One plays Minecraft (can be on for hours straight) and does a lot of typing in chat/commands and says theirs has always felt OK. The other did say that the keyboard was hot (rather than warm) one day, but they’d had a graphically intensive game running for hours and it was during the heatwave.
Hi
Where did you get your legion 7 5800/3070 from and how much did you pay? Many thanks
