Connect 3D X1900XT, Advice
Sharkypal said:
3500 XP, and games seem to play fine so I guess I was griping about nothing. Far Cry is definitely faster than my 7800 GTX 512 MB. I will put the FX-55 in tomorrow but I think I will have to order a 4xxx XP x2 tomorrow ;)!
Cheers for your help all the same ... and have a great weekend!
S
3500 XP? You sure its an XP :confused:
You mean the A64?
hi all in 3dmark 06 i just done the cpu test on its own - my score is 1634
i got a amd duel core 4400+
thats with out the cpu oc
is this score about right?
kinggost said:
lol should think so with the amount of money that gone into the system
I had a lot of things running in da back ground ..thats where the 31 marks went ;)
i spent a lot aswell 850 pounds on mobo ,cpu ,gfx
Hi,
I just downloaded 3dmark 06 but the setup program is asking for a password to unzip and install.
Have I downloaded the wrong version?
thanks
raja
Raja - If you downloaded from say guru3d, go back to the site, as it mentioned the zip password. I got it from there, and did the same as you. Then I checked again and noticed they mention a password.
This might be quicker than downloading it all again. I think the password was just before you have to click the "i agree" kind of terms and conditions bit.
Hope you see this in time ;-) (HTH)
-casw1000
I get over 4000 on 3dmark06 (cant remember exact score) and i dunno if thats good... My cpu isnt overclocked and it gets a real crappy score of 700 on the cpu test with like 0-1 fps in the test :( dunno if thats normal for a 3700+ SD but games run fine i just wish i could get more juice out my system get a 3dmark score i can be proud of for the system ive got.
3DMark Score 7650 3DMarks with 7800gtx 256mb in sli
SM 2.0 Score 3538 Marks
SM 3.0 Score 3416 Marks
CPU Score 1821 Marks
1 - Return to Proxycon 28.157 FPS
2 - Firefly Forest 30.815 FPS
CPU Tests
CPU1 - Red Valley 0.583 FPS
CPU2 - Red Valley 0.91 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 29.545 FPS
2 - Deep Freeze (SM 3.0) 38.774 FPS
3DMark Score 5574 3DMarks with single xt1900xt-x
SM 2.0 Score 2270 Marks
SM 3.0 Score 2401 Marks
CPU Score 1775 Marks
1 - Return to Proxycon 17.043 FPS
2 - Firefly Forest 20.786 FPS
CPU Tests
CPU1 - Red Valley 0.567 FPS
CPU2 - Red Valley 0.889 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 23.724 FPS
2 - Deep Freeze (SM 3.0) 24.292 FPS
Hi,
I got 3d mark06 up and running, cards are overclocked, 4800 cpu remains unclocked. I got around 8300 in crossfire with 1900xt.
I suppose these marks ar reasonable, but even with these cards the 3d tests frame rate drops to 18 at a certain point. I think graphics cards are coming out so quickly, there really isn't a quantum leap in perfomance between models. Developers are not forced to optimise software to get the maximum performance from the hardware, as there is always a new product on the horizon. I remember how much they squeezed out of the playstation after a few years.
Thanks
Raja
