pdw8 said:The best option would be fibre optic cable. It has no distance or speed limitations(real world) but is very expensive as it the kit you need to hang off it.You could use something like cisco 2950G switches in each bulding with one acting as the gateway with your routers and WAN facing kit.
You would not be able to use any other type of cable on those distances, CAT5/6 is good to about 90m.
What sort of scenario is this? A business campus?
The only other alternative would be a business grade wifi network but I have no knowledge of this type of kit.
---Lex said:problem is there are lots of obstacles like car parks, different height buildings etc. What about if fiber was not an option?
what are the options:
- fiber
- wireless (what type?)
- line of sight? (is it the same as wireless?)
- other? (what else is there?
bitslice said:see old post about install notes for a really cheap wireless link I did
http://forums.overclockers.co.uk/showthread.php?t=17592983&highlight=wireless
other cheap options would be (google the text)
laser LAN link
IR LAN link
ISDN LAN link
Broadband VPN LAN link
then we are onto microwave £££ etc.
btw.
if you include a tiny weeny ickle miniscule bit more info in your post(s), you might get a more useful reply...![]()
---edit: beaten to the post---
Lex said:Yes it MUST be secure and it must be quick.
paul@ said:BT Kilostream/megastream
Laser is very expensive, fibre is ££, get BT to do the dirty work for you.
(the actual rental was relatively low). Laser is just capital outlay and depreciation.
bigredshark said:well, fibre is by far the best choice, laser would be the second choice and is reasonably secure but can be very flaky at times, we've replaced all our laser links with BT LES100 circuits now...
Really, assuming you're looking for high bandwidth, the choice is between DIY fibre and getting BT to do it (LES circuit)
If you can deal with less bandwidth, a high grade wireless setup might work, a company with a lot of experience in the field would be your best bet here, though a company i worked for had one of these links and have since replaced it with fibre.
as has been pointed out, fibre is very expandable, you could upgrade to 10gigE on the same fibre, or run CWDM to get multiple links over 1 fibre pair.
FordPrefect said:I'd also go with the LES circuit as its means that if you have problems BT fix it for you instead of you having to sort that out as well. May very well end up cheaper in the long run. I believe tho that LES circuits are no longer available but have been replaced by something similar Ethernet Extension Service instead of Lan Extension Service.
