Connecting case fans
14 Dec 2009
Troedyrhiw, Wales
Hi all, im stuck!
I'm nearly finished my build but i dunno where i should connect the Silverstone FT02 case fans. Do they all connect to the motherboard?
And also what is a power fan connector?
Specs:
FT02 case
Asus P6x58d-e
i7 950
6Gb memory
Promalitech Megahalems with 2 Viper fans
Many thanks :)
I'm pretty sure you can connect your 3pin case fans to any 3 pin fan header on your motherboard including the power fan connector (which is 4 pin?).
Or you can buy 3pin to molex adaptors and power them from your PSU directly.
