Connecting DisplayPort monitor to 2017 iMac?
Commissario
16 Oct 2002
In the radio shack
I'm going to be ordering my new 27" iMac early next week and it suddenly occurred to me that I don't think I have any way of plugging my Dell P2414H monitor into it. It's connected to my 2011 iMac using a Thunderbolt to DisplayPort cable.
What's going to be best for the new iMac? A USB-C to Thunderbolt adapter or a specific USB-C to DisplayPort cable? Will something like this do the job?
Thanks.
I don't have a 2017 iMac but thought I'd have a look and try and find an answer, so hope this is right. According to this Apple Support document: https://support.apple.com/en-gb/HT204154
The Thunderbolt 3 (USB-C) - Thunderbolt 2 Adapter doesn't support Mini DisplayPort Displays
Thunderbolt 3
For Mac models with Thunderbolt 3, you can use a use a Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter to connect to Thunderbolt devices like displays and external disks.
Note that although it uses a Mini DisplayPort connector, the Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter doesn't support connections to Mini DisplayPort displays. Also, this adapter supports only one powered Thunderbolt 2 device on a USB-C equipped Mac.
I would be looking for a dedicated USB-C to DisplayPort Cable. Also noticed the cable you linked to in your original post only supports 4K @ 30Hz. You may want to look at a cable capable of supporting 4K @ 60Hz incase you decide to upgrade your external display to a 4K model at a later date: https://www.amazon.co.uk/Plugable-D...tTM-3840x2160/dp/B01EXKDRAC?tag=macworld09-21
Hope this helps you Feek :)
Edit: Just found this post on the Apple Support forum - https://discussions.apple.com/message/31970505#31970505 looks like a cable rather than an adapter is best to avoid issues.
Good spot on the cable, thanks. I'll be ordering the iMac on Tuesday or Wednesday and will order that cable at the same time.
