- 5 May 2004
HI ALL
i have never bothered with the mic and line out on front of case before but just got a sugo and a gigabyte matx mobo which says it uses the realtek 880 chip
now if i connect the front audio panel headers to the mobo so i can use headphones does the back then become disabled it says there are software settings but do you have to keep switching this
well exact words in manuel are
to enable ac97 audio on front panel connector to support ac97 audio mode go to audio control panel click i/o tab in analoug area click tool icon and then select disable front panel jack detection this action completes ac97 config
what does that mean will the back then become disabled
or will it allow ac97 from front panel and use the 880 chipset to still work the back for my speakers aggggggggggggggh
