Connecting front panel switches etc
29 Nov 2004
hi there, i'm in the middle of putting my new computer together, and have run across something i'm stuck on. i'm trying to connect the power switch and led connectors, but am not sure which way round they go - which one is the positive. the connectors each have a small arrow on one of the legs - is this the positive? don't want to connect it up wrong and fry the board before i've even got it going.
You only need to get this right for the LEDs and the speaker, the switches will work regardless. Yes, the arrow on the connector usually indicates the positive. That wire will be the coloured one of the two, the other will most likely be black. On the motherboard, use the manual to identify the positive post.
