For the last few weeks my connection has been dropping out a lot more than it ever has. It always seems to happen around evening time but has also happened at other times of the day. It'll play up for a variable amount of time and then suddenly everything will be back to normal again which leads me to believe it's the ISP. This has only happened recently as it has been fine for months. It has happened once before in the past when the connection just went to the dogs all of a sudden.
That's the status page from the modem which is a AM200. The line stats are really poor but it's always been like that even before the problems. The ISP is Pipex (TalkTalk). I've done the usually and checked to make sure all filters are OK and the modem is plugged into the master socket.
Also, it sometimes will not pickup a gateway when connecting and the stats will show something like this:
Which requires a modem reboot to correct.
EDIT: Another thing that seems to happen. Right now it has stopped dropping but certain sites are no longer accessible or very slow. The OCUK forums on the other hand aren't too bad and still quite fast. Gaming still seems fine with latency around ~40ms.
Code:
DSL Status
DSL Status: UP
DSL Modulation Mode: G.992.1 (G.DMT)
DSL Path Mode: INTERLEAVED
Downstream Rate: 1984 Kbps
Upstream Rate: 896 Kbps
Downstream Margin: 2 db
Upstream Margin: 11 db
Downstream Line Attenuation: 45
Upstream Line Attenuation: 59
Downstream Transmit Power: 15
Upstream Transmit Power: 11
LOS Errors: 0
PVC Connection
PVC Status: UP
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Autodetect: Disable
VPI: 0
VCI: 38
Code:
PPP Login: Up
Internet IP Address: 81.178.129.16
Internet Netmask: 255.0.0.0
Internet Gateway: 0.0.0.0
