i've been on bt max now for about 4 months and my connection is always dropping, on average i would say around 4 or 5 times an evening which is a pain if i am doing any online gaming, i've had 3 bt home hubs and have now got a voyager 2500v which is better than the home hub but still drop's the connection.
i've contacted bt loads of times and they can't find anything wrong, here are my router stats, i haven't got a clue whether they are good or not, can anyone see a problem with them or suggest anything i could do
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:00:42:13
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 2336 Kbps 448 Kbps
Noise Margin 15.1 dB 10.0 dB
Line Attenuation 60.0 dB 31.5 dB
Output Power 17.6 dBm 12.3 dBm
K (number of bytes in DMT frame) 74 15
R (number of check bytes in RS code word) 16 16
S (RS code word size in DMT frame) 2 8
D (interleaver depth) 16 4
Super Frames 148969 148967
Super Frame Errors 2 0
RS Words 5064954 1266219
RS Correctable Errors 247 12
RS Uncorrectable Errors 30 0
HEC Errors 2 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
HEC Errors 2 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
if that line attenuation is right it's well bad. 60dB downstream! You really want it around the 40's below.
