i've got a problem with my connection dropping that i've had for ages and it's never been sorted out i was previously with BT but have since moved to adsl24 and the problem is the same, it's much worse at peak times, BT's stance on this seems to be as long as it works most of the time then thats ok.
it normally disconnects and re-connects again in about 30 secs but it's very annoying, at the moment i'm on a 2 meg fixed connection but i have tried it when i was with BT on a 1meg fixed and it makes no difference, i was just wondering what peoples thoughts are on this, is it just down to the quality of my line and something that i will just have to put up with, here are my line stats.
Line Mode G.DMT Line State Show Time
Latency Type Fast Line Up Time 00:00:05:41
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 2272 Kbps 288 Kbps
Noise Margin 14.6 dB 15.0 dB
Line Attenuation 60.0 dB 31.5 dB
Output Power 18.6 dBm 12.1 dBm
K (number of bytes in DMT frame) 72 10
R (number of check bytes in RS code word) 0 0
S (RS code word size in DMT frame) 1 1
D (interleaver depth) 1 1
Super Frames 20054 20052
Super Frame Errors 9 0
RS Words 0 0
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 0
HEC Errors 2 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
although i'm supposed to be on a 2meg fixed i'm not getting anywhere nere that
Date 06/04/08 19:29:34
Speed Down 1395.51 Kbps ( 1.4 Mbps )
Speed Up 245.89 Kbps ( 0.2 Mbps )
Port 8095
Server speedtest1.adslguide.org.uk
RS Words 0 0
HEC Errors 2 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
Port 8095
