I think I’ve followed settings for the sub and 667. I’ve laid out the procedure in painstaking detail below. Apologies for the ramblings. I thought by doing this I might find the problem myself.
According to the 667 manual the main steps are as follows:
Step 1A
Connect the subwoofer input jack to the SUBWOOFER 1 or 2 jack on the Yamaha 667 with an audio pin cable. I have used one of the stereo audio cables (insert link) – a pair of which I purchased with system from richersounds. I’ve inserted one end of one of them into SUBWOOFER 1 jack on the Yamaha 667.
Step 2A
Set the subwoofer volume as follows:
Volume: set to approx half (or slightly less than half)
Crossover Frequency: set to max
So I’ve set volume to 11 o clock position and crossover frequency to 150 Hz (as this is the max on the BXW-10)
Step 3A (not sub specific)
3.1 Check unit, TV, sub
3.2 Place YPAO at ear height
3.3 Turn on receiver
3.4 Connect YPAO
3.5 On screen, select ‘measure’, then ‘enter’ – performs measurement and displays result.
According to the Monitor Audio BXW-10 sub manual the main steps are as follows:
There are two possibilities for input – 2 x stereo, 1 x LFE. All 3 are RCA connection. As I am connecting to a Yamaha 667 (and not a stereo amplifier), I presume I should follow instructions for using the LFE input on the sub (is this correct?). Also, by using this, the crossover frequency shouldn’t matter, as the crossover function being controlled by the AV amplifier (Yamaha 667) to which it is connected.
Even though this is the case, suggested settings are provided for the cross over frequency. They are as follows:
Type of Main Speaker
Monitor Audio Product Crossover
Control Setting
Small stand-mount/ bookshelf speaker RX1; BX1/2; R225HD/250HD;R oneHD 60-90 Hz
(Theres a more extensive list but I’ve only included this as I have pair of BX2’s). Thus there is a conflict – as the Yamaha 667 manual suggests setting it to 150Hz and the BXW-10 sub is suggesting to set it lower at 60-90Hz. I think the hierarchy is the Yamaha so I’ve set it to max of 150Hz. Plus, shouldn’t this just mean that it kicks in more often? (Although not really as the cross over is set in the Yamaha 667 menu).
Volume Control – Advice as follows: Start with the volume at a low level and increase the level control until a balanced sound is established. If using an AV processor or AV receiver amplifier, the system can be adjusted by the test tone function within the set-up features. (Refer to the set up section in the AV processor or AV receiver amplifier user guide.)
Thus I’ve used the recommended setting of 11 o clock as per Yamaha 667 manual.
Phase Control Switch – Advice as follows: it should be noted that in most cases the phase control switch should be set to 0 degrees, especially when using a digital AV processor or AV receiver amplifier.
Thus I’ve set it to 0 degrees.
Power Mode Switch with On-Auto-Off Facility
I’ve switched this to on.
(Should the LED immediately go to green to indicate it is operational? Or will it only go green when it is ‘on’ AND it receives a signal? (e.g. test signal from auto setup procedure with the YPAO mic)).
12 Volt Trigger Input ~ Centre Pin = +12Vdc
Monitor Audio recommend using this function and a lead is supplied. This 12 volt signal is supplied by the AV amp/receiver and tells the BXW-10 to turn on from standby mode. This allows a more accurately controlled auto on/off function, and is far more energy efficient. When using the 12v trigger, the Power Mode Switch (7) can be in any of the three positions, for it to function correctly.
I’ve not connected this and won’t bother trying until its up and running. Unfortunately at the moment it is very energy efficient as it aint working at all.
Its plugged in.
Summary
So I’ve set it up as best with the guidance from both manuals.
- Using 1 cable (stereo audio cable) to connect ‘Subwoofer 1’ jack on the ‘PRE-OUT’ section of the Yamaha receiver to the ‘LFE IN’ at the back of the sub.
- Set volume to 11 o clock position (on sub)
- Set cross over frequency to max 150Hz (on sub)
- Turned on the sub (its plugged in, mains power switch is on, power mode switch set to ‘on’) and a red LED comes on to indicate standby mode at the front, and the LED at the back is red.
- Turned on the Yahama 667 – standby screen appears on TV
- Inserted YPAO microphone into front of Yamaha 667 for autosetup
- Pressed enter on remote to start – it selects ‘Measure’ in on screen menu for autosetup
- It then finds my front left, centre, and front right, but not my sub.
So basic setup according to the manuals doesn’t seem to work for me. Now onto some variations to standard suggested settings.
Variation 1: Changing crossover frequency to 80Hz. (Now within recommended range as per BXW-10 manual)
- I changed crossover setting on back of sub to 80 Hz
- (I didtn turn anything of and on again – presume there is no need?)
- I then performed ‘Measure’ step again. Still doesn’t pick up sub.
Variation 2: Change to Subwoofer 2 on AVR
- Turned off Yahama 667
- Turned off sub
- Took out cable from ‘Subwoofer 1’ and inserted into ‘Subwoofer 2’
- Repeated as per summary above
- Still doesn’t pick up sub
Variation 3: Used different cable to connect sub and Yamaha 667.
Variation 4: Used different socket for plugging in sub to main power.
Variation 5: Tried to setup the sub manually and then played BD to check.
None of the above worked.
Note that I am using Philips stereo audio cable that I purchased with system:
http://www.philipsshop.ie/Spec She...10_pss_eng.pdf
Am I doing something wrong with the cables hooking-up the sub to the Yamaha 667?
Any other suggestions?
