Did either the speaker or amp manufacturer tell you to wear rubber shoes when connecting your gear?....No. Did you get an electric shock?....No. A little bit of common sense will tell you that we are dealing with the same connections as you've been happily playing with since setting up your system....and you're still alive to tell the tale. As Mark M succinctly put it - "Just touch the ruddy cable"Hi lucid,
Thanks for getting back. But whatever about pants, should I be wearing some type of rubber soled shoes trying to do this? Well at least I've had a good NYE if it all comes to an end shortly.
Just a quick clarification before I try this. I should try it with the cable plugged into the 'LFE In' at the back of the sub first. Then if nothing, try it in 'L Line Input' second?
Do I need to lick anything? Feels like I should - either the cable or my finger. Hmmm....
By the way, I have now connected all my speakers in case that was the problem. Now running 7, but still no 7.1 as of yet... Didn't make the slightest difference. Tried it again both manually and autosetup - again setting all the speakers to small.
Lick whatever you want - and please spare us the details - but you're making a hell of a mountain out of a very small mole hill.
