Controversial topic time.
Disclaimer: This doesn't necessarily apply to 8800GTX...
Compare these 3DMark06 results:
Conroe @ 3.6Ghz, X1900 Crossfire @ 680/800, Catalyst 6.8
Conroe @ 4.3Ghz, X1900 Crossfire @ 680/864, Catalyst 6.9
Gained about 650 points on the CPU tests going from 3.6Ghz to 4.3Ghz, but lost FPS and points on the other tests - presumably because the 3.6Ghz run was done on a totally fresh install of XP with nothing else installed except updates, whereas the 4.3Ghz run is on my everyday XP install with various things installed.
Sobering reading though, just goes to show you don't really need exotic cooling to get the best out of the current cards on the market.
Code:
[size=5][b]3DMark Score 11335 3DMarks[/b][/size]
SM 2.0 Score 4713 Marks
SM 3.0 Score 5145 Marks
CPU Score 3117 Marks
Detailed Test Results
Graphics Tests
1 - Return to Proxycon 36.314 FPS
2 - Firefly Forest 42.243 FPS
CPU Tests
CPU1 - Red Valley 0.982 FPS
CPU2 - Red Valley 1.583 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 49.688 FPS
2 - Deep Freeze (SM 3.0) 53.222 FPS
Code:
[SIZE=5][b]3DMark Score 11672 3DMarks[/b][/SIZE]
SM 2.0 Score 4684 Marks
SM 3.0 Score 5066 Marks
CPU Score 3766 Marks
Graphics Tests
1 - Return to Proxycon 36.29 FPS
2 - Firefly Forest 41.769 FPS
CPU Tests
CPU1 - Red Valley 1.193 FPS
CPU2 - Red Valley 1.902 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 49.025 FPS
2 - Deep Freeze (SM 3.0) 52.297 FPS
