Hi all,
As in the title, i am thinking about jailbreaking my ipod touch, done it in the past and i loved it, but i am now quite nervous! dunno why.
If it goes wrong, is it easy to restore it? is it as simple as putting into DFU and clicking Restore?
Also, i dont want to start fiddling with all the system files, not just yet anyway! So, is Winterboard that bad? When does it start to get laggy? i used to have loads of themes etc... and it seemed fine tbh! Is it better to keep all the themes etc... to a minimum?
Last one, do i use Winterboard for putting more add-on's into the Notification Centre?
Thanks in advance,
Cam
Thanks in advance,
Cam
