constant blue screens, potential ram problem? help!
3 Dec 2005
hi
i had been getting constant blue screens recently, so ran hd tune on my boot drive to look for errors. sure enough there were plenty. so assuming it was screwed, i reloaded windows on a different hd with no errors. problem is, i am still getting loads of blue screens (there is literally nothinh else on the pc, completely fresh install) whats the next thing to check? i am assuming ram (i have 3 x 1gb sticks in there). how do i go about testing ram? is there a program that will do so (hoping i can stay in windows long enough to run it)
cheers
try it with just 1 stick of RAM, repeat, changing the stick each time until you have tested them all, then hopefully, if it is the RAM you will identify the faulty one/ones :)
Check your event logs. This is helpfull in diagnosing problems.
Also list your full specs., including any cpu/gpu ocing. This will also help others to assist you.
Download mem test, link below to test your ram, this will create a bootable cd wich you run from startup, you will need to change your boot options in the BIOS.
http://www.memtest.org/#downiso
Is your system overclocked try running at stock.
Like others have mentioned list full specs including psu model.
Hi Guys
Have dl'd memtest. Do I have to run it on each stick separately? Or can I leave all of them running overnight?
PSU - Corsair hx520,
CPU - C2D E6750 @ 3.2ghz
RAM - 3 x OCZ PC2 6400
GFX - 8800GTX @ stock.
Motherboard - abit ip35-e
How do I reset my cpu to defaults?
Hi Guys
Have dl'd memtest. Do I have to run it on each stick separately? No Or can I leave all of them running overnight?Yes
You should be able to do it in your bios, default settings.
Did you check your event log?
