Constant network problems (have to restart adapter)
31 Jul 2004
Surrey
I have an asus p5k delux and I use the onboard network connections, I have sky broadband with the netgear router they supply and its all connected via cables.
Now regardless of which port I use (there's a realtek and a marvell port) I often (several times a day sometimes and then days or maybe a week or 2 without then several times a day for a while again) have dropouts where the internet connection stops working, the little icon in the bottom right has a red cross over it or a yellow triangle saying I have either limited or no connectivity.
Over time the connection comes back or I can diagnose the fault using vista which gives me the option to restart the adapter which normally fixes it, sometimes it doesn't and I have to reboot.
All the while if I'm using my laptop with wifi it works fine so I guess its not the actual connection.
Anyone any idea what might be wrong? I've had this with another router and iirc even different mobos, I just seem to have real trouble with this.
Any help appreciated! :)
Tried using a static IP for the network?
Might be DHCP on the router?
Just a wild stab in the dark though.
how would I do that? I'm good with watercooling and rubbish with networking! is that likely to be the issue??
Tried a different network cable?
no, its all hidden under skirting boards and it's quite a long cable, guess I could buy another, would a cable make me reset the adapter and then work again?
It's most likely something you are running on the PC that your not running on the Laptop.
I'll take a guess that it is P2P software that is killing your connection.
I'd say network cable is a good bet if the problem is replicated with different routers and different network adaptors - the only consistent there is the cable. But if it's miles long and hidden under skirtings trying a different one is probably easier said than done.
Incidentally you wouldn't need to reset the adaptor, just plug it in and go.
