- 2 Apr 2006
kinetic747 said:
Flibster said:In another famous SR-71 story, Los Angeles Center reported receiving a request for clearance to FL 60 (60,000ft).
The controller replied "Sure, if you can get to it, it's yours."
The pilot then said "Thanks, Hubu flight xx descending to FL 60.
LOL. Owned.Flibster said:In his book, Sled Driver, SR-71 Blackbird pilot Brian Shul writes: "I'll always remember a certain radio exchange that occurred one day as Walt (my back-seater) and I were screaming across Southern California 13 miles high.
We were monitoring various radio transmissions from other aircraft as we entered Los Angeles airspace. Though they didn't really control us, they did monitor our movement across their scope.
I heard a Cessna ask for a readout of its ground speed."90 knots" Center replied.
Moments later, a Twin Beech required the same. "120 knots," Center answered.
We weren't the only ones proud of our ground speed that day as almost instantly an F-18 smugly transmitted, "Ah, Center, Dusty
52 requests ground speed readout."
There was a slight pause, then the response, "525 knots on the ground, Dusty."
Another silent pause. As I was thinking to myself how ripe a situation this was, I heard a familiar click of a radio transmission coming from my back-seater.
It was at that precise moment I realized Walt and I had become a real crew, for we were both thinking in unison. "Center, Aspen 20, you got a ground speed readout for us?"
There was a longer than normal pause. "Aspen, I show 1,742 knots"
No further inquiries were heard on that frequency.
Scuzi said:FL60 = 6,000ft
FL600 = 60,000ft
I've heard quite a few gems in my time, some of which aren't repeatable on here. One recent one had me in stitches
I was working the London TMA North East Dpeartures sector with my instructor listening in. I was relatively new to working on live traffic and was still getting used to the RT procedures. A British Midland Airbus A320 got airborne off Heathrow on its way to Amsterdam, it's callsign was BMA6XC 'Midland six x-ray charlie'. It checked in as follows...
"London Control, Midland six x-ray charlie passing two thousand four hundred for six thousand on a brookmans park five juliet departure"
"Midland sex icks-ray charlie.....err correction, midland six x-ray charlie, squawk ident, after passing four thousand feet fly radar heading zero one five"
"Ideant, after passing four thousand, heading zero one five, midland six x-ray charlie"
A few minutes pass while the aircraft passes under inbound traffic until I can give it further climb.
"Midland sex icks-ray...correction, Midland six x-ray charlie climb flight level one five zero"
"Climb flight level one five zero, midland six -xray charlie"
Another minute or two passes while I talk to numerous othe aircraft.
"Midland sex icks ray chaa...correction, midland six x-ray charlie, turn right heading zero eight five"
"Right heading zero eight five, midland SIX X-RAY charlie....you're bloody sex on the brain aren't you!?"
I had to get someone to take over because I was bent over laughing. It was the way he said it![]()
that one had me laughing to no end.kinetic747 said:What day would that be?
Flibster said:The pilot then said "Thanks, Hubu flight xx descending to FL 60.
.Everykinetic747 said:What day would that be?
.Exactly what I was thinking as I read it!Scuzi said:FL60 = 6,000ft
FL600 = 60,000ft
Nazbit said:Some of these are legendaryIts a side to the aviation industry I wish I hadnt seen though, I will be scared ******** on the next flight I go on
After every flight, pilots fill out a form, called a "gripesheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by pilots (marked with Defect) and the solutions recorded (marked with Action) by maintenance engineers.
Defect: The autopilot doesn't.
Action: IT DOES NOW.
Defect: Seat cushion in 13F smells rotten.
Action: Fresh seat cushion on order.
Defect: Turn & slip indicator ball stuck in center during turns.
Action: Congratulations. You just made your first coordinated turn!
Defect: Whining sound heard on engine shutdown.
Action: Pilot removed from aircraft.
Defect: Pilot's clock inoperative.
Action: Wound clock.
Defect: Autopilot tends to drop a wing when fuel imbalance reaches 500 pounds.
Action: Flight manual limits maximum fuel imbalance to 300 pounds.
Defect: #2 ADF needle runs wild.
Action: Caught and tamed #2 ADF needle.
Defect: Unfamiliar noise coming from #2 engine.
Action: Engine run for four hours. Noise now familiar.
Defect: Noise coming from #2 engine. Sounds like man with little hammer.
Action: Took little hammer away from man in #2 engine.
Defect: Whining noise coming from #2 engine compartment.
Action: Returned little hammer to man in #2 engine.
Defect: Flight attendant cold at altitude.
Action: Ground checks OK.
Defect: 3 roaches in cabin.
Action: 1 roach killed, 1 wounded, 1 got away.
Defect: Weather radar went ape!
Action: Opened radar, let out ape, cleaned up mess!
Defect: Left inside main tyre almost needs replacement.
Action: Almost replaced left inside main tyre.
Defect: Test flight OK, except autoland very rough.
Action: Autoland not installed on this aircraft.
Defect: No. 2 propeller seeping prop fluid.
Action: No. 2 propeller seepage normal. ***. 1, 3 and 4 propellers lack normal seepage.
Defect: Something loose in cockpit.
Action: Something tightened in cockpit.
Defect: Dead bugs on windshield.
Action: Live bugs on backorder.
Defect: Autopilot in altitude-hold mode produces a 200-fpm descent.
Action: Cannot reproduce problem on ground.
Defect: Evidence of leak on right main landing gear.
Action: Evidence removed.
Defect: DME volume unbelievably loud.
Action: Volume set to more believable level.
Defect: Friction locks cause throttle levers to stick.
Action: That's what they are there for!
Defect: IFF inoperative.
Action: IFF always inoperative in OFF mode.
Defect: Suspected crack in windscreen.
Action: Suspect you're right.
Defect: Number 3 engine missing.
Action: Engine found on right wing after brief search.
Defect: Aircraft handles funny.
Action: Aircraft warned to "Straighten up, Fly Right, and Be Serious."
Defect: Target radar hums.
Action: Reprogrammed target radar with words.
Defect: Mouse in cockpit.
Action: Cat installed.
Defect: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
Action: Took hammer away from midget.
