Controller for fighing games
6 May 2009
I have a 360 USB pad but find it a weird shape and much harder to use than when I remember using a PS1 or SNES pad for hours on end. After a short time it hurts my fingers
What would be the best pad / controller for fighting games such as street fighter? I read that the Sega Saturn USB pad is great but can only find cheap knock-offs and the original is supposedly $300+ if you can even find them.
Should I used use a PS1 pad and PS1 > Windows adapter like I used to years ago?
If you're looking to get seriously into fighting games you should really get an arcade stick.
Alternatively, there are some decent Madcatz (I know, I know...) pads specifically designed for fighting games that you can get.
Stay away from madcatz fightpads very bad build quality mine broke first day 0 abuse opened it up and could see why the shoulder buttons are just 2 small microswitches glued on with a tiny bit of inadequate thin black foam glued on top.The build quality is poundland the only one to use is the ps3 pad it's the least bad D pad, in the long run much better to learn to play with a stick.
