Is there any software out there that can control 3 pin fans on my radiator plugged into the mobo using the gpu temp as a sensor.
I know smartfan would be a candidate but it's too out of date to work with AM4.
Preferably free software, but if there's a reasonably priced bit of software that would be ok too.
I tried the VGA fan header adapter route, but it looks like my fans need to be PWM to get that working properly so it would require ditching the 2 fans I just bought and buying another 2. Not preferred.
Thanks
Thanks
