cookie manager for ff2
12 Feb 2006
Surrey
is there an add on for ff2 that will allow you to lock and mark them cookies as safe, so that they never get deleted when deleting all cookies? i ask as every now and then i delete my cookies but as there is a lot i like to keep such as for this forum, i end up having to select each one at a time which gets tedious very quick
also i have asked this before but the suggested add on turned out to not be what i am after, bascially looking for an add on that allows you to split the tabs up and view 2/3/4/5 at the same time, like notepad++ if you have ever used it or mathon browser . I was tried splitview but this isn't that great and doesn't give the same as just having 2/3 tabs open and viewed at same time.
thanks
Yeah. I know. :p SplitView is all I know off and frankly I didn't use it for long. A mate of mine found it and I tried it but I didn't really like it. :)
