Does anyone else here put tomato ketchup in there bacon sandwiches?
Check out here: http://www.smoker-cooking.com/build-a-cold-smoker.htmlToday was day 3 and still quite a lot of juice coming off when I did the final rub just now, tomorrow it comes out of the rub and will be left for a day.
I am considering making a smoker, it is possible to make a cold smoker without the tubing and very cheaply using (of all things) a soldering iron.
MB
found it pretty hard to cut each slice with any kind of precision
Have you got an extremely sharp knife, it also helps if you partially freeze the meat to firm it up.
I'm going to get a ham knife, I think it'll make cutting a lot easier.
Jbuk, mine didn't go purple but it did get a lot darker and firmer.
Damn Sainsburys were out of pork belly so no bacon for me until Sunday
Well I cooked some last night and it wasn't as good as I was hoping
When cooked it looked gray in parts and the flavour wasn't there
Well it's true but not critical. I am using cheap table salt as I'm still experimenting and it's cheap, but the sodium levels are higher in table salt because of the anti caking agent.Just been doing some reading up on home curing of meats etc and found a post by someone who seemed a little over dramatic, saying not to use table salt as it contains horrible anti-caing agents, and that you MUST use pure salt from a health food shop.
Is this true or is it nonesense?
