- 19 Nov 2011
Hi guys,
So I have finally finished my loop consisting of:
D5 Pump
EK Xres 140
1x black ice GTX 360 mm
2x black ice GTX 240mm
All fans are in push and pull.
Now, the CPU temps peak at around 55 during normal use, and 70c during IBT, this is @4.6 GHz on an i7 4930k.
My last loop had worse temps when gaming say 60 ish, but water temp was always around 33.
Now my new loop the tempvis always 4 degree delta of room temp. For example it reach 35c last night during stress testing, after a few minutes of being idle the water temperature dropped to around 33, this equaled to a delta of about 4.5-5 degrees.
I have delta all of the radiators, and while the top one is warmer (straight from the CPU I presume) they all where shifting hot/warm air.
I turned up the Pump to max speed, a bit of air was shifted and the Res water went down a little, I left it like this all night, and intend to by the close of today so I don't think there is an air lock.
Oh just to add, I had all if the fans just above the slowest setting, as I have an NZXT mix, would an Aquerao be a better choice to manage such a setup?
Is this anything to be concerned about?
D5 Pump
EK Xres 140
