Coolbits: Detect Optimal Frequencies
24 Sep 2005
Stoke
How accurate is this? I've decided to finally to overclock my card and was going to use this as a rough guide to it's potential. Please please tell me it's the most inaccurate thing ever :D
Default core: 450mhz
Detected core: 463mhz
:eek:
When i used it on my 6600GT it overclocked it way too high on the core and really low on the mem. It works for some but not for others. I preferred doing the manual way so that i know that it's stable.
It never works properly for me...it over did my 5700u (mem way too high - core too low), was well under on my 6800, and reboots with my 7600gt.
I'll try manually then. Still hope it was a bad detection. Are the 7800GT's bad clockers? Or did i manage to get myself a bad egg? :D Thanks for the replys.
Mine didnt clock very well mine was around the same :( You've got to remember 7800GT's have delta which add another 40mhz on when in 3d mode so you'd be running at around 500mhz core. I flashed mine to a 1.5vcore bios and it didnt really help either :p
Didn't quite understand you there :D What's delta?
Not sure but i know it adds 40mhz to the core clock once its started to run in 3D mode. Rivatuner should show this too.
Hmmm i never knew that. In coolbits it says my 3d clock is 400mhz, and the memory is at 1000mhz.
Yep it shows the clocks how they are but in the bios the delta is set and most are set to 40mhz. It will only add it to your core though. Your memory will stay the same.
I understand you now :D
I'm going to give the memory a go this afternoon. Hope i can get a good boost out of it.
OK. I feel really stupid now. The default clock speed isn't 450mhz it's 400. So i guess a 63mhz increase isn't too bad. :o :o :o
