Coolbits Problem
22 Apr 2003
I have a 7600gt AGP and drivers 91.47. I have down loaded coolbits and the overclocking option is not showing up in the control panel.
What am I doing wrong?
Are you talking about the nvidia control panel or the Winfast that came with the leadtek...
i see clocking in the nvidia pabel, but not the other.....
also this works to open them in rivatuner:-
Edit .cfg file to enable 7300, 7600gs 7600GT overclocking window... on
version v2.0 RC 16......
7600GT AGP are 2E0 and NV4B
so mod .cfg file line entry.......
NV4B = 390h-39Fh
to
NV4B = 390h-39Fh, 2E0h-2E2h
and should work for 7300GT, 7600GS 7600GT. All of them AGP.
I can not see the overclocking option in the Nvidia control pannel. As for the rest of of your post mitch007 I did not understand it, sorry.
No one with 7600GT AGP and 91.47 drivers that can help me get this coolbits working? Can you run through where to get it and exactly what to do?
I ran coolbits on my 7600GT AGP and it opened up clocking.
Just to be sure:-
Right click on desk top and click properties.
Settings
Advanced
this should allow you to see a tab with GeForce 7600GT on it, click this.
if coolbits has worked the additional tab window on the left should have a clock frequency settings listed
RivaTuner is another application that allows you to modify a lot of the graphics card settings, but with out the mod i listed the current release does not recognise 7600GT or 7300 series cards yet. So a manual edit of the .cfg file (part of rivatuner setup) is required. it is easy, you can get RivaTuner at www.Guru3d.com.
the forum there is also helpful....and a good source of additional information..
