Cooler for 9800x3d
acs
acs
21 Jan 2025
UK
Need advice on a good cpu cooler for the 9800x3d. Bought the Antec Flux Pro case so I think I have a lot of room at the top for the radiator.
Needs to be black and no RGB on the fans. Seen reviews on Twitter and YouTube that the Lian Li Galahad II Trinity performance is one of the best performing coolers but not sure if there are any more cost effective options or it’s totally worth it
Any help much appreciated.
I’ve got a Antec Flux Pro, will they work?
i want to say in the front yes, top no the ran is only a few mm bigger then a normal AIO but it dose make for fit fitting it
EDIOT: looking at the case tbf you should be ok
Is air cooler better than aio?
Pros and cons for each type really. I have air cooling but watched a few videos. Never used WC before but what I gather..
AIO Pros
Lower tempetures, but really best on very hot CPU's in the first place ie Intels. No point water cooling a 65W CPU for example as good air will be more than capable
Helps with case ventilation as well
Frees up space around CPU so clearence on tall memory modules, more space to fit/remove top NVME and GPU
Has dropped in price a lot ie £100 for triple 420 is a bargain
Cons
If it leaks (rare, but slightly possible) will trash motherboard, GPU and PSU.
Pump can be noisy ie not silent, if it fails CPU will fry as water isn't being moved around.
Need a case suitable for radiator fitting and correct placement ie rad at bottom is worst
Can have a slimmer case as CPU block isn't high (but rad's are still wide though)
VRM fan can be noisy, and non standard fan size type (would like standard 60mm/80mm fan ontop)
No alarms if pump dies
Finite lifespan in AIO, as the coolant evaporates through pipework over time decreasing the amount of liquid
Need to keep rad fins clear of dust, can damage fins etc
Rad can be very big
A single 120mm rad will be no better than decent air cooling.
Performance will degrade over time (years) things like sludge, growth in tubes etc. Ideally want a system you can top up, flush out and change liquid. You can't do that with Artic as they're disposable items after 10 years or so (which is still great value for money)
Air cooling
pros
Affordable, and if your CPU is mediu TDP output, air cooling will be sufficient
Can be quiet if choosing right fans
Can run without fan, as case fans right next to it might be enough for cooling
Basically once fitted there is no maintence apart from checking the CPU fan still works, clearing dust from fins etc
cons
Large and heavy, blocks GPU and NVME slot, fan gets in the way of memory
Makes cable routing a bit more tricky and working in the case
If you're trasporting PC, I'd probably remove HSF in case of damage, ie with some 1KG that's a lot of mass.
AIO Pros
Cons
Rad can be very big
Air cooling
pros
cons
The thing is my room gets very dusty so I’m not sure but I wasn’t aware of if an aio fails then the cpu will get fried, is that a likely thing to happen
pump failure isn't common, but there is a slim chance. I don't know what the failure rate
Unless you notice it high CPU temps you could be using it with it no longer working. Unless you run coretemp often etc. I've emailed artic to include a buzzer in case of pump failure, that extra feature would be useful.
Your PC dust filters will reduce the amount of dust, so it's probably the same- just that the AIO fins are tighter packed so dust more likely to clog it up. A clean every six months should be fine.
Air cooling is good if you just fit it, leave it and never have to worry about, zero maintence. But WC does offer better temps quick search for that CPU . probably more required for the very hottest Intel i9 etc.
My 9800x3d with PBO overclock hits about 83-84 degrees after ~12 minutes of Cinebench Multi Core. I use a Thermalright Peerless Assassin 120 dual tower/dual fan cooler. I previously had a Deepcool single tower/dual fan cooler and with that one the 9800x3d hit 93 degrees under max load, which was too close to the thermal limit for my liking. So I upgraded.
During gaming sessions I max out at around 61 degrees (72 degrees with the previous Deepcool cooler), but the CPU load is usually well under 40% in the games I play. Idle temps are mid 40s.
All the above is with a room temperature of about 22 degrees."
Are you referring to the 360 or 420 one? And which one is the best out the 2?
I'm talking about the case clearance at the top .
Antec flux Pro 70mm
Antec flux midi 60mm
Arctic freezer 3 is 63mm so won't fit in the midi case at the top.
So as long as your case is the pro then the arctic will fit in the top. , which can take 360mm or 420 mm so either would be good .
  • Like
Reactions: acs
