Cooler for i5 760
28 Jun 2010
UK
A the title says i will be getting an i5 760 soon with the future to OC it never OC'ed before but i want to have the option to. So basically what should I be going for cooler wise for the CPU?
Also should i be replacing the fans in a case with better ones to keep the inside cool?
And one other question what should standard temps of the i5 and say GPU be if there are standard ranges that is.
im using a fenrir only issue is it blocks 2 ram slots when mounted with fan blowing towards back of case so had to mount backwards on my asus p7p55d-e, apart from that the temps are really nice
